very high fuel pressure
Old Jul 26, 2000 | 10:14 PM
poncho@home's Avatar
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
I have recently changed to 24# injectors and a installed and High volume fuel pump along with an AFPR..now I am showing 85 psi pressure and no matter what I do to the AFPR it doesn't change. My charcoal canister also got full of fuel...is it possible that my AFPR is faulty or my return line blocked? Any insights?
89 GTA 350 T-Tops White/Grey----Looking for a little more performance than stock!
Old Jul 26, 2000 | 11:02 PM
Vader's Avatar
poncho,
I'm guessing your FPR is not regulating at all, and won't allow fuel to bleed back through the return line. Your new pump won't last long at 85 PSI either.
Later,
Vader
"Some Body...Someone"
Old Jul 27, 2000 | 07:17 AM
Engine: 3.0
but why would my pump be pumping at 85 psi? It is a walbro high volume series...is there something else builing pressure?
Old Jul 27, 2000 | 11:06 AM
Cowboy's Avatar
I had this problem when I added my AFPR and after beating my head about what it was I took it all apart. I found that I had bent the guide rod inside the pressure regulator spring. I replaced this assembly and re-installed the AFPR hat and all was good.
I have since added SVO 24# injectors and a Walbro (Holley) **mp and had no further problems.
Hope this gives you some ideas.
'87 IROC L-98 with mods
'82 Pace Car with mods; not running
'96 Yamaha V-Max with mods
'98 Neon R/T
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
