Need to know location of all fuses/relays for fuel pump..
Old Apr 28, 2003 | 03:18 PM
BAK12484's Avatar
Well my car took a dump on me today and isn't running... had to tow the damn thing home w/ my Jeep through rush-hour traffic :\
Anyways, are there any other fuses/relays connected to the fuel pump besides the fuse underneath the dash? I'm almost positive it is the pump itself that is dead but want to make sure it's not a bad connection in between. And forgive me for not checking to see if the pump itself is getting any power yet, as I can't find my dad's voltmeter and have to wait until my buddy gets home from work to borrow his.
TIA.
Btw, its an '89 Firebird Formula
Old Apr 28, 2003 | 10:03 PM
Vader's Avatar
BK,
There is a fuse holder near the battery with a 20A fuse:
The relay for the pump is mounted on the firewall:
Other than the connectors along the way, that's about all there is. The relay has a parallel path through the auxilliary oil pressure switch, but the fuse is still the initial source.
Old Apr 28, 2003 | 10:16 PM
BAK12484's Avatar
thanks for the pics vader... knew I could count on you
Knew it was somewhere in the front corner but wasn't sure exactly where.
Strangely enough, I got the car working somehow. Was testing for the connector at the tank and got a reading of 6.5v (off the pink/red wire) or so (that normal or should it be 12v?)... anyways, after I plugged the connector back in I decided to try the car again for the hell of it, and what do you know, the damn thing fired up. So I am hoping it was just a loose connection, and not the fuel pump having a grudge against me.
Old Apr 29, 2003 | 07:42 AM
Vader's Avatar
BAK,
The pump should get full battery voltage. Less than that indicates a connection problem somewhere.
Ghettobird52
Jul 5, 2024 11:18 PM
Dialed_In
Aug 20, 2015 01:45 PM
AkDrifted
Aug 17, 2015 07:45 PM
kyleb24
Aug 15, 2015 08:24 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
