tranny leak
Old Apr 28, 2003 | 06:19 PM
Squeeks83's Avatar
Car: 1978 Chevrolet C10
Transmission: Turbo 350
tranny leak
ok well today i got around to fixing my exhuast leak and puttin my valve covers on after the head swap, ive ran the car a few times before this to make sure everything is right. well this is my problem i looked under the car after running it for a few minutes and there is a decent size puddle on the ground and smells like tranny fluid.
i take a peek, sure enought my tranny is leaking now, i was wondering
is this having to do with anything i might have done while the head swap its not the filler tube, its right, its also dripping form the tranny lines that go to the cooler at the front of the car.
Old Apr 28, 2003 | 08:56 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
if its dripping from the tranny lines and your positive its not the dipstick tube ( if you pulled it out when you did the head swap and then put it back in its very possible you may have made a small puddle which then started to run off) then i think you've found your problem..try cleaning it off really well and then look for the leak.
Mark_ZZ3
May 24, 2018 01:02 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Reid Fleming
Oct 10, 2015 09:56 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
