Ticking noise coming out of the engine
Old Jul 27, 2000 | 11:55 AM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
There is a small knocking noise which seems to be coming from the area where the valve cover is on the right side, but don't know for sure. After the engine warms up though, like 10 mins. of driving, the noise stops. I have switched to mobile synthetic about 2,000 miles ago - was i wrong to do that?
p.s. I didn't notice any power loss
Mods:Hooker Aerochamber 3" exhaust, gutted kitty,
March 2 piece underdrive pullies, smog pump gone,;these two made a very noticable difference.
14x4 K&N open air element filter
Eibach springs with KYB's are already installed up front. Gonna work on the rear soon.
Appearance: Harwood cowl hood, Z-28 wing, painted black-original color was light blue)
Stock Options:117,000 miles on motor, 5spd, TBI, 305, T-tops
Going to the track this summer, but i'm pretty sure i'm still in the 16's on the 1/4 mile (or maybe not any more)
Old Jul 27, 2000 | 12:37 PM
kevinc's Avatar
Car: 1982 Z28
Sears has a $12 mechanic's stethoscope that will make finding the source of the sound very easy. I had a slight "rattle" noise on startup and at high revs, re-lashed the rockers and replaced the distributor but couldn't find it. With the stethoscope, I found a loose bellhousing bolt that was allowing the tranny dipstick to rattle around.
You hear neat stuff listening to the engine while running, probe the oilpan and hear the pump whirring, etc.
-Kevin
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
Old Jul 27, 2000 | 12:48 PM
Car: 88 IROC
Transmission: auto
Cool!!!! Thanks, i think i'll try that
Old Jul 27, 2000 | 01:19 PM
NO RICE's Avatar
loose bolts on exaust manifold/header?
bad lifter?
rocker arms out of adjustment?
how is your oilpressure while it's ticking?
Old Jul 27, 2000 | 01:27 PM
Formula92's Avatar
Take a piece of broom handle and while engine is still cold, put handle against engine block in different locations,cup your hand and put against your ear. This will tell you if it's a rod knock or not. It should work on valve cover also.
92 Formula,305HO,Factory Oil cooler,Hyper-Tech Chip,Hyper-Tech Coil kit,Dual-Core Split-Fire wire set,Hyper-Tech Airfoil,Accel Fuel pressure guage mounted on fuel rail,Crane Adj Fuel Pressure Reg,March Performance Pulley set,Four Wheel Disc Brakes,WS6 Package,Dual Convertor Exhaust,3.42 Gear/w POSI,5Speed Borg Warner Tranny,Center-Force2 Clutch Set-Up,K&N Filter.
Old Jul 27, 2000 | 01:35 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Poor man's stethoscope: 3' of heater hose and a funnel. Or even, no funnel.
Like the other post said, you'd be amazed at the little sounds that come from each part of an engine. It's easier to hear stuff if you disconnect the belts. Of course you can't run it for a long time that way.
Old Jul 27, 2000 | 03:52 PM
Car: 88 IROC
Transmission: auto
My oil pressure gauge don't work, it hasn't worked ever since i bought the car. I'm gonna try the poor man's stethoscope and let you guys know what i hear. I don't want to have to pull the valve covers cause than i would need new seals, but i might have to.
theshackle
Sep 17, 2020 08:26 AM
pimp2303
Jul 27, 2017 02:03 PM
B_Dubya
Aug 26, 2015 05:09 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
