Under drive pulleys?
Old Jul 27, 2000 | 05:59 PM
steven's Avatar
What are under drive pulleys, what do they do, can i get them for my car, how much do they cost?
191(3.1)V6 Overhead Valve,Multi-Port Fuel Injection 1992 Pontiac Firebird,140 HorsePower @ 4400 RPM,180 FT/LBS @ 3600, Compression Ratio: 8:9:1, 3.42 Ratio Rearend,700R4 Transmition, check it out at www.geocities.com/my_92firebird
Old Jul 27, 2000 | 09:17 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Underdrive pulleys slow down your water pump and alt. to free up some extra H.P.You can get them for your car,I would suggest March pulleys.They will cost you around $200.00
Superman
Rev'n to Seven
Old Jul 27, 2000 | 09:20 PM
IROCET's Avatar
Car: 88 IROC-Z (Sold)
Engine: 5.7L
Well, underdrive pullies are simply pullies that are smaller than your stock pullies. They work by slowing down accesories. I have the three piece on my IROC and I noticed a difference in performance instantly. It is nothing like 100 lb/ft. more torque, but it is noticable. I am not sure if you can get them for a V-6, you might check with March Performance Pullies, which is where I got mine.
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
88 IROC-Z -- 350 L-98, 700R4, Flowmaster, K&N, MAF Sceens Gone, Airfoil, March Pullies, Comp Cams Magnum 1.6 Roller Rockers, Accel U-Groove Plugs, Accel 8.8 mm Wires, Hypertech Cap & Coil, Hypertech Chip, Hotchkis Strut Tower Brace, One Loud Stereo!
Old Jul 27, 2000 | 09:56 PM
Arctic White 91 RS's Avatar
Car: 91 RS/ 99 T/A/ 72 Vette/ 02 Z28
Engine: LSx/ Dart400
Transmission: M6/ M6/ TH400/ 4L60E
Axle/Gears: 4.10's / 3.08/ 2.73
White under drive pulleys can help free up horsepower, they also under drive the accessories. While I don't consider the water pump and accessory, all the applications for the pulleys I've seen under drive the water pump by 15-25 percent. If you drive where your car is in no danger of over heating or have improved the cooling system so that losing 15-25 percent of the water pumps flow is no big deal, it may be worth trying. I know in the summer it would cause my car to overheat in stop and go traffic. You will also want to make sure the alternator charges if you install them. The pulleys are great for race only.
Just my .02 worth...I know some are able to run under drive pullies without any problems.
Old Jul 27, 2000 | 09:58 PM
SLP had a set listed a few months ago for our 3rd Gen cars that were under $50. I dont recall the exact price.
Old Jul 27, 2000 | 10:00 PM
Tab92bird's Avatar
Umm, why couldn't someone just go out and find a pulley that is a little smaller than the stock one? wouldn't that be a helluva lot cheaper?
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
Navy8125
Aug 22, 2015 07:13 PM
mcquigg
Aug 13, 2015 02:26 PM
