Will these springs fit?
Old Apr 29, 2003 | 09:17 PM
Killogy's Avatar
Car: 87 Firebird Formula
Engine: 355
Will these valve springs fit in unmachined LG4 (416?) heads? Also, would I use stock size retainers?
Comp Cams Single Valve Springs - 1.250'' Diameter Single Outer Spring w/Damper.
Valve Lift up to .490''.
110# @ 1.700'' Closed, 285# @ 1.250'' Open,
Coil Bind @ 1.130''.
Old Apr 29, 2003 | 09:36 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Yes they'll fit.
Yes you'll use stock size retainers, however don't use the factory rotators.
customblackbird
Aug 15, 2021 10:16 PM
Street Lethal
Apr 30, 2019 12:14 PM
gixxer92
Sep 1, 2015 04:32 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
