Some explain PVC System to me........
Old May 1, 2003 | 03:38 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
also can this also make more oil burning come out of the exhaust?
also I do i check if it is working correctly?
Old May 1, 2003 | 04:02 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Its purpose is to flush combustion leakage and moisture out of the crankcase, and replace it with fresh filtered air. It helps your oil last longer and keeps sludge and varnish formation inside the motor to a minimum.
It uses a "calibrated vacuum leak" (the PCV valve) to allow the engine to draw crankcase air out through one valve cover. Fresh air is supplied into the other valve cover.
A properly working factory system will not cause oil burning. Aftermarket valve cover, on the other hand, can fail to separate the oil mist from the air, and may allow some oil into the intake.
Depending on what year of L98 was swapped into your 86 car, it may use the MAF system; in which case the clean air comes from a point after the MAF and before the throttle body, so that before it goes into the crankcase and then out through the PCV valve into the intake, it has passed through the MAF, and been counted.
RaverRacerX
Mar 17, 2026 01:49 AM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
1992Z28!
Nov 19, 2015 07:33 AM
BWilcox
Sep 20, 2015 12:19 PM
