Are rockers supposed to...
Old May 2, 2003 | 05:10 PM
Matty377's Avatar
Car: '86 Camaro
Engine: LG4
...wiggle around?
I readjusted my valves by tightening until the pushrod didn't spin then 1/4 turn more...but my #1 exhaust rocker wiggles around if I try to shake it. It's the only one that does this, so I readjusted it 3 times, still shakes around a bit. Should I go 1/4 turn more or is this normal?
-Matt
Old May 2, 2003 | 05:20 PM
rezinn's Avatar
They should all act the same when on the same part of the cam. Try bumping the engine over and see if it acts differently with some pressure on it. I normally go half a turn past zero lash. If I were you I'd go another quarter turn on each.
You are setting each one when the lifter is fully down(zero lift, valve closed), right?
Old May 2, 2003 | 05:37 PM
Matty377's Avatar
Car: '86 Camaro
Engine: LG4
Yeah, I'm setting them with both valves on each cylinder closed.
-Matt
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
KO1
16
Oct 15, 2015 05:00 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
mfp189
Sep 27, 2015 09:25 AM
