Rear hatch won't close tightly...
Old May 2, 2003 | 06:16 PM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
This is in regards to the '89 Camaro in the sig...
It was closing fine at the beginning of the week, but I noticed now that it doesn't close very tightly. By that, I mean that it closes, but I can still push down and pull up on the hatch and it will still move about a half an inch from top to bottom. It's latched enough that it won't open, but not enough that it's sealed tightly.
The motor still works fine--I can hear it engage and then stop after I lower the hatch. I do notice, however, that even though I close the hatch hard enough for one click, I don't really see the hatch pulling down when I hear the motor like I used to.
I think this might have started when a friend closed the back like he thought he should have (i.e. if the car wasn't equipped with a motorized hatch). (Have you ever met anyone that doesn't slam these back hatches? ).
Old May 2, 2003 | 06:54 PM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
rear hatch
people did that to mine more than a few times and it's still ok,.. but that still might have damaged it...
so suspect something is broken...
Old May 3, 2003 | 11:23 AM
sancho's Avatar
I'm trying to think of what could have broken, if anything. Checking it out visually, I don't see anything that looks broken. And, if something were broken in the motor/gear mechanism, I would know because the latching assembly wouldn't travel up and down (which it does)...
Old May 3, 2003 | 07:24 PM
sancho's Avatar
Well, I just took the rear panels off to take a look a the motor assembly, and several plastic fragments fell out. The whole moving assembly is now very loose, hence why the hatch won't close tightly. Dammit.
Since I need to get this fixed ASAP, I've got another question... I've got an '88 Camaro that is not currently being driven with a fully working rear hatch. The thing is, the '88 car does not have an indoor hatch release switch, and my '89 car (with the broken hatch) *does* have an indoor hatch release switch. So, my question is: will the unit from the '88 Camaro work in my '89 Camaro?
EDIT: Just realized something else... Assuming that I could swap the assemblies, I noticed that there's a black cable going from the keylock to the latching unit. How is that cable supposed to be disconnected?
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
