WTF!! Roll cage installation( the darkened directions!!!)
Ok... I got the main hoop in... time to grind and fit the pipes that go back and forward..... According to S&W directions the back pipes should be welded right over the gastank... Not only that its dangerous, but most important, the place where they tell you to weld them is a plane sheet metal cover. There is no way in can provide support NO SIR... I indeed you weld it there, the hoop would rock back and forth since the sheet metal IS NOT strong....
Anyways... would the place right next to the shocks(right above the rearend) be better to weld those rear bars... that seems like a strong point.... doesn't look as cool though...
'85 Trans AM LG4 5-speed: '68 327 from vette, stroked to 350, L31 vortec heads, .015" gaskets, comp cams XE 268, Edelbrock 600, RPM intake, headman hedders and 3" home made exaust system, ASCD ram air(formerly dirk's), rustoleum-black interior, 8 point roll bar is rusting away in the garage(waiting for lazy neighbor to weld it)
E.T. 13.6@106
Correction: lazy neighbor sold me his welder.
tuned carburator and a lot less weight since last trip to the track...
no more 275x60x15
it's 245x50x16
put a 3.73's a few days ago
me be faster next time I go...
E.T. 13.6@106
no more 275x60x15
it's 245x50x16
Car: 2000 Trans Am
Actually, it would be better to put them closer to the shocks since thats want you want to keep stabilized.
Are you making sure to put down a plate before you weld the tube down? 36 square inches per point that touches?
We put 6" x 6" plates down at each point on mine. Or any variation that gets you 36 sq. inches
-86 IROC
-S-Trim, Mini Ram, etc.
12.17 @ 113mph
THE crew: ICON Motorsports
-86 IROC
12.17 @ 113mph
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I have the SW setup and put 2 bars on each side. One goes to the top of the shock mount, the other to the frame rail in the very back, just like the directions I had. Not sure which cage you have, but you can see it on their website at www.swracecars.com and I have some pictures of mine on my page.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
http://www.geocities.com/MotorCity/Track/5604/
Miles
88 427 Camaro
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Take a look at the pics on my pages. My bar is a custom fabricated one but it'll give you some ideas on where to weld.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
Best ET on a time slip: 11.857
Best corrected ET: 11.233
Best MPH on a time slip: 117.87
Best corrected MPH: 125.46
Best 60 foot: 1.662
Racing @ 3500 feet plus density altitude!
Member of the Calgary Drag Racing Association
Best 60 foot: 1.662
ambainb
Apr 25, 2016 09:21 PM
