Spark Plug Gappin
Old May 3, 2003 | 11:23 AM
1982Camaro383's Avatar
Spark Plug Gappin
Question for you guys I have a 1982 Camaro with a 350 Chevy, with a full msd ignition. What is the best gapping to use for a compression ratio of 9.8.1. .050-.060 what is the best gap to set them at. I am using NGK TR5 plugs. Any help would be greatly appreciated.
Thanks,
Justin
1982 Camaro
Old May 3, 2003 | 11:35 AM
ede's Avatar
ede
i'd start at .045 to .050 and go from there
Old May 3, 2003 | 11:39 AM
MSD says with up to 10.5.1 it should be at .050-.060, 10.5-13 at .040-.050 and 13 and about at .035-.045. I am running at about 9.8 with vortec heads
Old May 4, 2003 | 08:37 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
I'm running my '350 with MSD 6AL/Blaster Coil and Gap at .045. Stock for my car was .035... stock for the heads with TPI was .045. .045 works for me. I don't see alot of benefit from over gapping.
If you go too big, you'll actually feel a decrease in power, but you wont feel any gains. IMHO.
Old May 4, 2003 | 08:41 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I always gap at .035 thats where the CE tester shows the most spark on any plug Ive tested.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
