How do I set the idle?
From: DeKalb, Streamwood, Arlington Heights, IL, USA
I have an '86 Firebird 2.8L MPFI, Auto.
I read how to set the idle in a FAQ, but i don't know what the ALDL is, and how to connect the terminals on the Idle Air Control valve. Ummm... help
Thank you
Thank you
The ALDL is a port that is under dash. It serves as the connectiob to read all the computer parameters on a screen. You can also "wire" it to report engine codes to be flashed on and off with the check engine light. I am not familar with setting the idle, or "minimum air", but I would get a service manual for reference.
Jerry
89 RS Lt Blue T-Tops T5
355 Crate, Compucam 2040
Pst Front Hotchkis Rear
Edle. TES 3" Flowmaster
Harwood hood, bla, bla, bla...
94 Z28, LT1 6M, Black
Most of the bolt-ons
Jerry
I took a pin and stuck it into the middle connector of the tps, and then read voltage from that to ground. That way you don't have to make a mess with jumper wires and whatnot... also, I'm pretty sure that after you disconnect the IAC you turn the ignition off, remove the connector in the ALDL, and then start the engine... That's how i did it in my 87 t/a anyway...
-Jeff
-Jeff
Street Lethal
Apr 30, 2019 12:14 PM
