there has to be an easier way to check fuel pressure?
Old May 4, 2003 | 10:23 AM
19WS6T/A91's Avatar
i am about to install a holley afpr. i checked the stock fuel pressure so that i would know where to start. there has to be an easier way to get the guage on there. i had to remove some bracket that was bolted to the plenum, to be able to get the the nipple. this is a pita!!! am i going to havee to do this everytime i check the fuel pressure?
Old May 4, 2003 | 10:25 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Install a gage for checking fuel pressure. Located under STB on passenger side fender.
Old May 4, 2003 | 10:33 AM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
You think that YOU have it rough? What about the TBI guys that have to disconnect the fuel line and install an in-line gauge? Talk about a PITA!
But seriously, it's relatively inexpensive to install a permanent remotely mounted gauge. That's my plan when I get the TPI in the car! If you wanted to get really trick with it, you could get a pressure transducer and an electronic gauge and be able to read it from in the car!
Old May 4, 2003 | 12:09 PM
19WS6T/A91's Avatar
how would i go about mounting one for good? i just bought hypertech guage and i think that they say it isnt designed for permanant mounting.
Old May 4, 2003 | 01:43 PM
DJP87Z28's Avatar
Your gage is only for test use. What you need is a Autometer FPG
& SS Braided line (36") with the correct AN fittings to connect the gage to the schrader valve. Check Summit for info.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
pimp2303
Jul 27, 2017 02:03 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
