my car is a hater!!!!!!!!!!!!!!!!
Old May 4, 2003 | 06:15 PM
black84-6spdz28's Avatar
well....went out last night and ran into this girl i have wanted like in forever.....we were having a great time......her sister insists we go to another bar....we jump in mine...this girl was loving it...got her all scared..lol...till...i am driving down the road and it vibrates all nuts and starts making weirds sounds...i killed it right off and popped the hood....no belts.......i grabbed the water pump pulley and it had come offthe pulley and part of the pump...grrrr...so we got stuck walking...still got her number though..heh....well...picked it up and i noticed the crank pulley was off center....2 bolts worked loose and fell out and the pulley came loose and took out the water pump and pulley...so i am at a junk damper.....
my engine is a balanced 357....now any 350 balancer will work...?????or do i have to get the same exact size balancer that it was balanced with?.....
Old May 4, 2003 | 08:43 PM
Vader's Avatar
If it was internally balanced, any old 350 damper should work fine. Dampers are neutral balanced for the shorter stroke SBCs.
Old May 4, 2003 | 09:05 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Re: my car is a hater!!!!!!!!!!!!!!!!
[i]so we got stuck walking...still got her number though..heh[/B]
At least you got her digits!!!
Old May 4, 2003 | 09:29 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Good job on getting the number anyway!
As for the balancer, that really sucks. I'll ditto what has already been replied about what will work, and also reccomend looking into a better than stock one. Maybe a Fluidamper? That's what I plan get for myself, but the $$$ don't allow at this time!
As for the belt loss issue, I'm there with ya! I was doing a couple back road runs a few weeks ago after making some adjustments when I found out that my A/C V-belt doesn't like much more than about 5200 RPM's! It flipped, and in the process took out the alternator belt. That was a big issue because I run the trigger for the fuel pump relay from the chake heater relay, which will not work unless the alternator is charging. Luckily, I was moving fast enough to coast it about 1/2 mile to the door at the shop! I also had it pop loose yesterday when letting a buddy hear it run, but I caught it before it took out the alt belt!
Old May 4, 2003 | 11:07 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Been there before... having something go wrong with my car at the absolute WORST POSSIBLE MOMENT!!
Oh well, at least you still got her number
And yea, a regular 350 balancer will work.
Old May 4, 2003 | 11:17 PM
i have the possibility of getting a steel damper from a machine shop for $120...i am gonna look into that
Old May 6, 2003 | 02:02 PM
well....i got a balancer from a friend for cheap so it goes back togethetr tomorrow..yay!
Old May 7, 2003 | 03:42 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You could always tell her later that you rigged the balancer to blow, just to spend more time with her! Should either get you bonus points, or get you slapped...
Old May 7, 2003 | 11:23 PM
hehe....well......i did get a lil longer time with her..
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
