oooookay, drum gears to a posi rear......
Old Jul 28, 2000 | 01:38 PM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
did the 9 bolt ever come as a posi drum set up. If so can i get a drum rear (ring,pinion, with the posi carrier) and install it all into my 2.77 housing posi/disc housing??? Boy,posi discs are hard to come by in any flavor
'89 SHAGGY IROC
so much to do , so little money
[This message has been edited by irocnroll89 (edited July 28, 2000).]
Old Jul 28, 2000 | 05:14 PM
'89 SHAGGY IROC
Old Jul 28, 2000 | 05:43 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
First, I don't believe the 9-bolt ever came with drum brakes.
Second, let me see if I understand your question correctly. I think you are asking can you take the gears (ring, pinion and carrier) out of a drum rear end and put it into a disc rear. Is this correct? If so, then yes this is possible, as long as they are both 9-bolts.
Scott
88 GTA L98
14.389 @ 95.2 mph, 2.001 60'
In search of the elusive 1.9 60 foot time.
Old Jul 29, 2000 | 12:18 AM
yep i want to get a drum rear/ or just the posi and gears from a 9 bolt and install in mine. I had a guy from a local yard today tell me he had a 3.27 ratio (must be 9 bolt) with drums so i'm looking in that direction cuz , no one out here has posi discs let alone 9 bolts I thought all B/W were posi ?????? thnx for the reply though....
'89 SHAGGY IROC
Old Jul 29, 2000 | 07:12 AM
ede's Avatar
ede
i have a 10 bolt disc rear i'd like to get rid of, but you're a long way off i i don't think i can ups a rear.
ICON Motorsports
F-body driver
Mar 6, 2023 11:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
rudolphschenker
Sep 4, 2015 02:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
