Centerbolt head conversion????
Old Jul 29, 2000 | 12:43 AM
Transformer's Avatar
Does anyone know if you can go from centerbolt heads to standard heads. Are there any mods that need to be done for this to happen. The reason IM asking is because a fried is selling me a set of 2.02 /1.60 SR torquer heads and man I really want to put them on my 88 5.7 TPI GTA.
88 GTA Hypertach TM pulleys C.T.switch MSD 3.70 gears SLP runners 1 3/4 headers 58MMTB 210-220-480 cam nitto NT555Rdrag radials
Old Jul 29, 2000 | 02:27 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
yes you could use the perimeter bolt heads,but waht you might need to check is the intake base.The two middle holes might need to elongated for it to bolt on the head.I dont know what else..
Daz
Old Jul 29, 2000 | 07:17 AM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
The holes are all you need to worry about. I did the opposite convesion this spring: I went to centerbolt heads on my 2-pc rear main shortblock in my 1984 Trans Am. I'm using an older Edelbrock performer intake, and I need to slot the four inner intake bolt holes. I sprayed the intake gasket with Permatex ultra-copper spray-a-gasket, and there are no leaks whatsoever.
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines,
5-point racing harness, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Speed-sensitive steering conversion, underdrive pulleys, Crane Hi-6 & more. 1.05g skidpad verified.
MoJoe
Sep 24, 2015 09:12 PM
509 camaro fan
Sep 6, 2015 10:43 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
J.C. Denton
Aug 31, 2015 03:11 AM
lt1z350
Aug 28, 2015 05:57 AM
