Can anyone explain a code 44, lean o2 sensor????
Old Jul 28, 2000 | 08:32 PM
86Trans Am's Avatar
Installed my headers and now the car runs like crap, threw a 44 the other day. Revs a lot but no acceleration, idles fine in park but when in gear, the rpms drop off and the engine knocks and then dies, unless you give it gas. The fuel is at 42psi. I did just turn it up a couple of pounds and it seemed to get better, could I need more presure?
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
Old Jul 28, 2000 | 11:15 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
You may need to replace your O2 sensor with a heated one. Apparently the way some headers are designed they don't provide enough heat for the O2 sensor to read correctly.
Scott
88 GTA L98
14.389 @ 95.2 mph, 2.001 60'
In search of the elusive 1.9 60 foot time.
Old Jul 29, 2000 | 01:18 AM
Mike92's Avatar
Would jet-hot coating affect the O2 sensor?
Old Jul 29, 2000 | 01:11 PM
86Trans Am's Avatar
Well going along with Vaders response in my other post, its probably not grounded at all because of the jet hot coating.
Can i just fashion a ground-strap out of a piece of wire?
Where do i get a "heated" o2 sensor, everyone at my local autozone has never heard of them?
thanks
Oh yea, the position of the o2 sensor is significantly further from the block than the original, reinforcing the idea of needing a heated o2 sensor.
Last night, rechecked the wires and tightness of the plugs, and bumped the fuel up a little more. This seemed to help something. It will hold idle in park, but in gear it will fall off and eventually die, a rough death, meaning it will really knock and cough before it dies.
thanks, i'm getting closer.....
1986 Trans Am
305 TPI
Old Jul 29, 2000 | 01:33 PM
Desert86Roc's Avatar
That is not right. Jet hot coating IS conductive, and does not affect your O2 sensor. Did you use a conductive anti-seize compound when installing the sensor? What does affect it is how far away the sensor is from an exhaust port. On TES headers, the sensor is right at the end of the primaries...so it seems to work alright.
Old Jul 29, 2000 | 02:04 PM
86Trans Am's Avatar
The sensor on the slp is right after the primaries also, but still much further than the stock set-up.
I guess its not a grounding problem if the jet hot is conductive.
getting closer.....
1986 Trans Am
305 TPI
Old Jul 29, 2000 | 02:38 PM
92TRANSAMWS6's Avatar
Somebody on here knows what o2 sensor you need to get and how to install it. Sure wish they would see this so they could help you out. All I know is that some new cars use a heated sensor, I think the one they say to get is for a VETTE. Not sure which year though. Sorry this the only help I can offer on this.
92 Trans Am/WS6/305/5Speed/T-Tops/Flowmaster Muffler/Ported Plenum
69 Camaro/427-currently awaiting restoration
Since light travels faster than sound, some people appear to be bright until you hear them speak.
Old Jul 29, 2000 | 02:45 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
'94 GMC/Chevy Sierra/Silverado, 350 TBI. It uses a 3-wire (heated) O2 sensor. It MUST be a 3-wire. The OBD-II 4-wire sensors WILL NOT WORK with your computer. They are easy to install.
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
About Me
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
85 Jimmy
Sep 30, 2015 07:56 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
