ES Poly motor mount part numbers?
Old May 5, 2003 | 08:45 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
What part number do I need to order? The guy at Summit racing told me I need to get ENS-3-1116G (24.95 a piece). I found some from prothane that are 33.95 for both of them though (PTP-7-506-BL). Which ones should I order? Thanks!
Scott
Old May 5, 2003 | 11:11 PM
alohamike's Avatar
Be sure you need them first. The motor mounts in our '92s are a total PITA to change. I have a set of Comp Eng's in my garage I'll sell you: I tried and gave up. The bolts you see from the top are attached to nuts on the bottom, which are not welded in place. You can sneak a long end wrench or socket with a universal up in there and get the nuts off, but good luck putting them back on. You could pull the pins on the lower control arms and drop them out of the way. Or you could pay someone else to do it or just not do it at all: the stock ones are pretty sturdy.
Mike
Old May 6, 2003 | 12:13 AM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
you sure you even want poly ones? Have fun watching your car shake apart, i've heard of people removing the mounts soon after they get them in because they can't handle the amount of drivetrain vibration that was sent through the car.
Though, your new engine may just rip the rubber ones apart
Old May 6, 2003 | 07:15 AM
Scott_92RS's Avatar
Car: 1992 RS
I've heard poly isnt so bad. Its not a daily driver anyway, so its not that big of a deal, as long as the shaking doesnt loosen bolts!
Scott
Old May 6, 2003 | 11:13 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I've got the ES; no problems with vibration.
JamesC
Old May 6, 2003 | 07:12 PM
Scott_92RS's Avatar
Car: 1992 RS
I decided to go with Moroso Solid mounts Thanks for the info anyway.
1992 Trans Am
May 10, 2023 07:19 PM
twest2k2
Aug 24, 2015 11:26 AM
armybyrd
Aug 10, 2015 09:23 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
