How do you install cruise cntrl lever?
Old May 5, 2003 | 09:00 PM
warrior_91's Avatar
Car: 86 T/A
Transmission: 700-R4 Auto
I just bought a cruise control lever and I need to put a new one in. How in the he** do I go about doing this? Do I need any special tools or anything?
86 Trans Am, 5.0 L, 305 ci, 4bbl, True Dual Exhaust.
Old May 5, 2003 | 09:48 PM
joshp14's Avatar
Tools needed: Hands, small socket set, wire or string.
Take off the lower panel above where your feet go and find the wire that goes down the bottom of the steering column and plugs into a harness under the dash. Unplug it and tie a string or wire to it. Grab the lever and pull straight out (make sure it's in the off position before doing this). Feed wire back through plastic white sleeve thats sits under column by tying the string to the new plug and plug back in. Viola!
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
perZ
Aug 21, 2015 05:51 PM
Bull86
Aug 10, 2015 05:43 PM
