WTF HAPPENED?please help
Old Jul 28, 2000 | 10:43 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
After making my final pass at the track,I checked everything out looked good,loaded car turned key blew oil out all over oil filter onto ground what happened?
86 IROC mods:T.E.S.,Flowmaster muffler
T.P.I.S. airfoil,ported plenum,March
pulleys,Accel 8.8wires,supercoil,ign.mod.
RAM AIR induction,gutted MAF,
B&M shift kit,3.73 rear gears,Accel afpr,Hypertech stage 2 chip,Random Tech.cat.,Lakewood lower control arms,Lakewood adj.panhard rod
"The more I learn about women,the more
time & money I spend on my IROC"
Old Jul 28, 2000 | 11:07 PM
Vader's Avatar
Sounds like you split the filter housing or blew the neoprene gasket. Was the filter tight? Was it a Fram?
Later,
Vader
"Some Body...Someone"
Old Jul 28, 2000 | 11:15 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Did you just change your oil and left the old seal stuck to the block double sealing it? It's kinda guessing what happened without knowing where the oil came from. There might be a pressure fitting beside your oil filter. Maybe a copper line blew or a fitting cracked.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
Best ET on a time slip: 11.857
Best corrected ET: 11.233
Best MPH on a time slip: 117.87
Best corrected MPH: 125.46
Best 60 foot: 1.662
Racing @ 3500 feet plus density altitude!
Member of the Calgary Drag Racing Association
[This message has been edited by Stephen 87 IROC (edited July 28, 2000).]
Old Jul 28, 2000 | 11:25 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Vader,
As a matter of fact it was a Fram.Why does that matter,do Fram's have that problem?The oil was changed only 1500 miles ago,Mobil 1 5w30,and the filter was installed by the same guy who installed the motor last July and goes over this car every Sat.He gets mad if I donot bring it by every week.
Old Jul 29, 2000 | 10:22 AM
Vader's Avatar
IROC,
That's odd - the BEST oil you can get and the WORST oil filter... Maybe the builder was thinking they would even out somehow?
Don't EVEN screw around with them any more. Get AC filters, PCV's, etc. (I had a similar problem with a FRAM PCV valve) Saving a few bucks on an oil filter could have cost you your engine. It's a good thing you were alert enough to catch it. There are a lot of other decent filters on store shelves, but given the vast number of choices and private labelling, this is just another example of why you should stick with the original equipment.
"Fram" is a four-letter word and it begins with an "F". What kind of car should use them?
Later,
Vader
[This message has been edited by Vader (edited July 29, 2000).]
Old Jul 30, 2000 | 12:20 AM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Vader,
I picked up the filter and oil for my car.I am impressed that you recall me asking you about which oil to use on my new motor.
Old Jul 30, 2000 | 12:29 AM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Sorry about that,didnot realize that I had posted oil brand earlier.It's been a long day,had to rebuild motor,didnot catch it soon enough.
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
RS Reaper
Oct 17, 2018 07:52 PM
racereese
Oct 3, 2015 03:46 PM
