just put new tie rods on.. what are proper torque specs?
Old May 6, 2003 | 07:36 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
i just put new tie rods on my car and i wanna make sure they are torqued properly.. what is the proper torque specs for drivers side tie rod end to spindle and to the center link and pass side to spindle and to centerlink.. i guessed at 35 ft lbs for both but i dunno if thats even close.. anybody know the correct specs?
Old May 6, 2003 | 07:57 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
From chiltons manual, not sure what is what:
Ball joints:
89-91: 83 ft lbs
lower control arm pivot nuts:
87-91: 67 ft lbs
rebound bumper:
82-92: 20 ft lbs
stabilizer bar link-to-control arm:
82-91: 15 ft lbs
stabilizar bar mounting bracket-to-frame
85-92: 39 ft lbs
strut-to-knuckle bolts
87-90: 203 ft lbs
strut-to-upper mount nut
89-91: 46 ft lbs
upper mount-to-wheelhouse tower
89-92: 18 ft lbs
This is out of a Firebird Chiltons manual, not a camaro.
Hope this helps some.
Matt
Old May 6, 2003 | 08:05 PM
89RsPower!'s Avatar
eh nope dun see em in there also does anybody know the specs from the centerlink to the idler arm and pitman arm?
Old May 7, 2003 | 08:09 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Based on the hardware size, it should be 40-45 ft-lbs
Old May 7, 2003 | 02:56 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
From Haynes
Steering KNuckle to tie rod end nut 35lbs
Tie rod clamp nuts 168in lbs
Tie rod to intermediate rod nut 35lbs
Pitman arm to intermediate rod nut 40lbs
idler arm to intermediate rod nut 35lbs
Idler arm to frame nut 50lbs
Pitman arm to steering gear nut 180lbs
Old May 7, 2003 | 05:50 PM
89RsPower!'s Avatar
thanx
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
TreDeClaw
Jun 22, 2021 08:21 PM
theurge
Aug 21, 2015 12:46 PM
gwade12
Aug 8, 2015 08:17 AM
