car wont start
Old May 6, 2003 | 09:32 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
ATTN : vader
my motor starts to crank but as soon as the first bit of juice hits it it drains the battery and the volts goto zero....you go back on the key outta ignition and the volts got back up but only to 12
Old May 7, 2003 | 11:14 AM
Vader's Avatar
Benny,
There are a couple of common possibilities:
1. The battery is sulfated and has no reserve capacity. A load test will determine whether that is the problem;
2. You have a marginal connection at the battery, ground, or starter (more likely). What happens to the interior lights when you crank the engine?
Old May 7, 2003 | 05:18 PM
Car: 83 Camaro
Transmission: th350
allready tried raplacing the battery......i dunno bout the lights cuz i aint got a bulb in the dome or anything but my amp and volt meter go to 0 when the starter tries to kick in
Old May 8, 2003 | 06:04 PM
Car: 83 Camaro
Transmission: th350
ttt.......also.....can you get starters tested to see if they are bad
Old May 9, 2003 | 04:23 PM
Car: 83 Camaro
Transmission: th350
ok i just checked and the interior lights stay on even when i crank it and the volts goto zero
Old May 10, 2003 | 07:50 AM
Vader's Avatar
I'd start by inspecting the connections at the starter,including the fusible links. You have a marginal connection there somewhere. You should also inspect the grounds at the inner fender and firewall.
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
