help help please!!!!!!!
Old Jul 29, 2000 | 07:55 PM
87-305's Avatar
I'm pretty sure that my slave cylinder has popped through at the end and isn't working. how easy is a slave cylinder change before i have to work tomorrow morning? the auto parts store opens at 9. help please
Old Jul 29, 2000 | 08:05 PM
Andy89RS's Avatar
I think you can only get the master and slave along with the hose as a complete set. Since it's already filled and pre-bled it shouldn't be too big of a deal to change. Before you go and spend any money though, have someone operate the clutch while you watch the slave. Also check the fluid level in the reservoir.
"Racing is life. Everything else is just waiting." - Steve McQueen - LeMans
305 TBI, T-5. 15.4@92 mph
Member Southern California Third Gen F-Bodies
AOL IM: Andy89RS
Old Jul 29, 2000 | 10:50 PM
87-305's Avatar
the local parts store has just the slave. i know that it is leaking from in between the back of the slave and the boot. it leaks heavily when the clutch is pressed and the diaphram is out. i need to know if you need a pin popper for the hose or if i can just get a wrench around it.
Old Jul 29, 2000 | 11:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You'll need a punch for the hose. Be prepared to be real patient when it comes time to bleed it.
Old Jul 30, 2000 | 12:02 AM
87-305's Avatar
why is that? how long will the prosses take?
Old Jul 30, 2000 | 09:33 AM
87-305's Avatar
can i just change the slave cylinder or do i need the master and the slave to be changed? please i need help, i have to be done before 6 today
