quick, proper ohm resistance of TPI injectors (and a question about said ohms)
Old Jul 29, 2000 | 02:09 PM
mbarland's Avatar
My supervisor at work (who used to be a mech at TPIS) told me to check my injectors resistance to help diagnose a problem (I haven't posted about this problem, so don't be surprised if it doesn't sound familiar ). My injectors are putting out 16.x ohms, my boss thought it should be around 12.x (but wasn't sure).
Now, is that about right, or are my injectors funky? and Is there a way to tell the flow capacities of the injectors by thier resistance (I seem to recall the previous owner mentioning flow matched injectors...)?
Old Jul 29, 2000 | 03:22 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I believe that 16ohms is what they should be.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jul 29, 2000 | 04:38 PM
Stuart Moss's Avatar
You cannot determine flow rate based on resistance .
Old Jul 29, 2000 | 06:51 PM
mbarland's Avatar
Thanks guys, 16 seemed right. Wish I could have an easy way to find the flow rates.
Thanks again.
Old Jul 30, 2000 | 10:08 AM
Vader's Avatar
Mbarland,
Bosch injectors can be serviceable down to 12 ohms. The flow has no relationship to the resistance of the solenoid (unless the resistance is zero or infinite, of course).
You can perform a "go/no-go test" to determine if any fuel is getting through the injectors in a couple of ways.
1. One method is to perform a power-balance test. Start the engine, allow it to reach operating temperature, then unplug the IAC electrical connector while the engine is idling. Unplug the electrical connector from one injector and monitor the engine RPM as it is disconnected. The drop in idle RPM should be relatively equal through the firing order. Replace the electrical connector and go on to the next injector. You need to realize that the ECM will sense the RPM drop and attempt to compensate by adjusting the IAC, which is why it was disconnected in the first place. Compare the RPM drop at each cylinder. Don't forget to replace the IAC connector. If one or more injectors caused little or no change in RPM, it is not flowing fuel at the correct rate. NOTE: This test will not be accurate if the ignition system is not in good order or compression is low on a cylinder.
2. The other method is done with a fuel pressure gauge, test connector, and stopwatch. You can fabricate a test connector from parts available from your local auto parts store. Connect the pressure gauge to the test valve on the right fuel rail. Turn on the ignition until fuel pressure stabilizes (about 45 PSIG). Turn off the ignition and monitor fuel pressure. If the pressure drops rapidly, your test results will be inconclusive and you cannot use this method. If the pressure maintains without dropping, connect yout test connector to an injector and to a 12V source. The pressure should begin dropping. Measure the amount of time until the pressure drops to 20 PSIG and make a note of this time. Disconnect the test connector and turn on the ignition to rebuild fuel pressure. Move to the next injector and repeat the process. Compare all the times when you're finished. If one or more of the injectors takes a significantly longer time to bleed off fuel pressure, it is not flowing at the same rate as the others.
Neither of these tests will indicate any problems with spray patterns, only flow. But if an injector isn't flowing properly, you can bet the spray pattern is poor. If you determine that you have a weak injector, I'd advise contacting Rich at Cruzin' Performance.
Later,
Vader
"Some Body...Someone"
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
Brcharrelson
Aug 26, 2015 07:47 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
