OUT OF SERVICE please please help!!!!
Old Jul 30, 2000 | 09:43 AM
87-305's Avatar
my hydraulic clutch is dead. i'm certain that it is the slave cylinder that is bad. do i need to buy the clutch assembly as a hole, or can i just replace the slave? i've heard it both ways, and i need to know so i can drive my car to work today. thanks
Old Jul 30, 2000 | 09:45 AM
Vader's Avatar
87,
You can rebuild or replace the slave cylinder. Don't forget to bleed the system once the cylinder is replaced.
Later,
Vader
"Some Body...Someone"
Old Jul 30, 2000 | 09:46 AM
87-305's Avatar
thank god, i didn't want to have to do the whole thing. what steps should i follow when bleeding? thank you
Old Jul 30, 2000 | 10:17 AM
Vader's Avatar
87,
Since the system is relatively small and the slave is mounted below the master cylinder, it will tend to bleed itself when the clutch pedal is relaxed. You can bleed excess air from the slave by loosening the hose fitting while the system is under pressure. The process is similar to a brake bleeding procedure. Monitor reservoir fluid level for a couple of days to keep the correct level as the last of the air purges itself.
Later,
Vader
Old Jul 30, 2000 | 01:42 PM
87-305's Avatar
i've replaced the slave cylinder and i am trying to bleed the system. the pedal has very little resistance, does this have anything to do with bleeding it, or is there something else wrong?
Veaceonee
Sep 29, 2016 08:15 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
eustodp
Sep 20, 2015 05:09 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
