Line Lock
Line Lock
What exactly is a line lock? what does it accomplish, and how do you install one? Just heard about it a little while ago.. and wondering if anyone can throw me the specifics of it. thanks
-Ben
1987 5.7L L98 GTA-
Current Mods: Gutted Cat, !MAF screens, Gutted Air Box. K&N, Ram Air, Throttle body coolant bypass, AIR system removed, 3" pipe to flowmasters, dual 12" electric fans, 4 core alum radiator, 160* stat, high output h20 pump and alternator, Accel Cap, rotor, 8.8mm wires, Bosch Plats, AFPR, Performance chip(unknown kind), Nitto NT555r 245/50/16 drags rear, Yokohama Advan 032r 245/50/16 fronts, JVC KDSX939 Head unit, Kenwood Excelon 4x6's, Kenwood Excelon 4 way 6x9's, Kenwood 606c amp, Power Acoustic Crossover, 2 JL 10w0's in custom bandpass box.
Best Run: R/T .601; 60' 2.010; 330' 5.990; 1/8 9.154@76.89mph; 1000' 11.997; 1/4 14.489@ 96.78
(only mods at that time were the K&N, exhaust,chip & no drag radials)
#077 Central Florida F-Bodies (http://www.cffb.com)
-Ben
1987 5.7L L98 GTA-
ok, it's starting to make sense now... does anyone have any writeups on installing one? Just curious whether it would be worth the time/effort
-Ben
1987 5.7L L98 GTA-
-Ben
1987 5.7L L98 GTA-
there was an artical in chevy HP a few months back that reviewed all 3 makers set ups and gave installation instructions. if i recall they are all very similar, moroso, hurst, and tci.
ICON Motorsports
ICON Motorsports
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Racers use a line lock (roll control) for a couple of reasons. First of all it's usually always plumbed into the front brakes AFTER the proportioning valve. It's just a solinoid. When you step on the brakes then push the line lock button and release the brakes, the front brakes are held on until the button is released.
It's used for waterbox burnouts so the front brakes hold the car and the rear brakes aren't dragging during the burnout.
Manual transmission cars will also use it on the starting line so they don't accidently roll through the staging lights.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
Best ET on a time slip: 11.857
Best corrected ET: 11.233
Best MPH on a time slip: 117.87
Best corrected MPH: 125.46
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
[This message has been edited by Stephen 87 IROC (edited July 30, 2000).]
Best 60 foot: 1.662
