Distributor questions
Old May 8, 2003 | 04:04 PM
TheLG4Whore's Avatar
Car: '86 Trans Am
Transmission: TH700R-4
Axle/Gears: 10 bolt 3.73
I just bought and MSD distributor model #8489 and I need to know if it has to be used with a crank trigger system such as model number 8610.
I was under the impression that I could use this distributor without the crank trigger setup.
any help is very welcomed
thank you
Old May 8, 2003 | 05:10 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Looks like you need a crank trigger with it.
Old May 8, 2003 | 08:05 PM
Car: '86 Trans Am
Ya I found that out once I checked back at the summit racing web site.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
beastin91rs
Oct 9, 2015 07:38 AM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
