Advanced Timing how much
Old May 9, 2003 | 02:28 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
I don't have a timing light so I know, I know, I shouldn't guess. But I did. I saw that the base of the distributor was at the factory "scatch" mark so I advanced (counterclockwise) it about 3/32". Will someone give me a guess how many degrees that might be? Oh, I have an 83 LG4.
BTW, It feels quicker. Could be my imagination.
thanks,
phil
Old May 9, 2003 | 03:15 PM
ede's Avatar
ede
there is no factory scratch mark, you're guessing if you don't have a light and so is anyone else that trys to figure out where you're at.
Old May 9, 2003 | 08:57 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Well my 91 Caprice 5.0L had a "factory scatch/cut" across the distributor base and the intake. So I figured that the scatch/cut on my 83 was factory as well. Maybe not. ...and I agree it would be a guess how many degrees 3/32" would be, that is why i ask if some of you experienced engine guys could tell me NOT where my timing is set, BUT rather if you advance it 3/32" from a mark on the distributor base, approximately how many degrees would that advance the timing.
phil
Old May 10, 2003 | 12:21 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Well you can figure it out yourself. Measure the diameter of the distributor cap and use the formula circ = dia*pi = 360 degrees, then take your 3/32 and divide by the circ and multiply by 360 degrees, this will tell you how many degrees 3/32" is. Get it.
Old May 10, 2003 | 07:30 AM
85TPI400's Avatar
There is no way to really figure out what it is at other than with a timing light. If there ever was a factory scratch mark, the wear on the timing components would make it inaccurate to use.
Keep in mind if you are looking to get a certain amount of degrees, when you do use a timing light it has to be double checked after you lock down the distributor as it has a tendancy to move when you are tightening it down.
Good Luck!
Amillionoh7
May 24, 2020 08:01 AM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Thirim
Aug 9, 2015 06:19 PM
djmarch
Aug 9, 2015 05:27 PM
