Tech / General EngineIs your car making a strange sound or won't start? Thinking of adding power with a new combination? Need other technical information or engine specific advice? Don't see another board for your problem? Post it here!
You can do what the factory did - eliminate teh fusible links and install a 60A fuse in place of each one, or use a 6" length of wire that is two AWG sizes smaller than the wire it is protecting.
