Bolt Torque specs?
Old Jul 31, 2000 | 12:16 AM
ZaphodB's Avatar
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
Bolt Torque specs?
What are the torque specs for the bolts for the plenum, intake and heads?
'89 Camaro IROC-Z 5.7L TPI - Mods Under Contruction :-)
Edelbrock TES Headers, SLP Airfoil, K&N Filters, Relocated MAT
Accel 8mm Wires, Ed Wright Fastchip Stage II/160 stat
Over in the cold country of Sweden!!!
http://www.controlteam.com/~zaphodb/ZaphodB-IROCZ89.jpg
Old Jul 31, 2000 | 07:55 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Heads 60-65 ft lbs; intake 30-35 ft lbs. Start at the center and work your way out a little at a time; for instance on the heads, run them down tight by hand with a small ratchet or something, then to 30, then to 45, then to 60. Use non-hardening sealer on the head bolts since they go directly into the water jacket.
Torque specs almost always are a function of hardware size and thread.
AussiePr0nCar
Mar 6, 2020 04:04 PM
redmaroz
Apr 25, 2017 07:14 AM
deracer
Apr 11, 2016 12:04 AM
gixxer92
Sep 1, 2015 04:32 PM
