Idle problem on carb rebuild
Old Jul 30, 2000 | 10:01 PM
David Trimble's Avatar
I just rebuild my stock carb (Rochester Quadrajet) on my '84 T/A - I didn't get so far as to pulling the mixture control solonoid as I was more interested in cleaning the body and replacing the gaskets. However when I reinstalled it, I get a bad idle. That is, the engine idle keeps changing on me, apparently as the engine temperature changes. I think the mixture control solonoid is still functioning as I can hear it buzzing away, but I'm wondering if I knocked something out of adjustment. Is it pretty easy to do on these type carbs? Can it be fixed/readjusted or am I just better off buying a rebuilt and putting that in?
Thanks!
Original owner - '84 T/A w/stock 305HO 5-speed
[This message has been edited by David Trimble (edited July 30, 2000).]
Old Jul 31, 2000 | 10:27 AM
I think I found part of the problem- the mixture solenoid plunger was bent. Not the plunger itself, but the flat piece that it goes thru. This is the piece that the mixture needles and idle air bleed contact with.
Anyone wanna take shot at this? I'd like to try to fix the carb- I just priced a rebuilt at $250 + core
Infested
May 22, 2018 11:56 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
GVMV
Aug 16, 2015 08:01 PM
hokis
Aug 9, 2015 03:57 PM
