backfire of somesort?!
Old May 11, 2003 | 08:30 AM
sennap1's Avatar
Car: 91 TRANS AM
Engine: 350 V8
Transmission: 4L60
Axle/Gears: 3.43
ok guys,i own a 90 firebird 336 cu inch TBI,formerly a 305 lo3.... anyhoo a couple days ago noticed a slight bog or backfire- if you will,under load, and it didnt do it again till this morn.... THIS TIME its severly bad!it idles fine-but any normal gas given and (she boggs soo baddly) i had to nurse her home from work.i went ahead and checked for trouble codes and(NONE)!i checked for loose spark plugs..(none). i took off the cleaner lid......whist shes running, and gave her gas, and the left injector coughed at me...? is it the obvious.....{injector}? or could it be the {TPS}? ORRRR maybe perhaps water in the tank??? IT IS RAINING BUCKETS RIGHT NOW!---but,it wasnt raining when it (FIRST HAPPENED) need help guyz,please point a fellow third gen head, in the right direction! TY BRAD! by the way shes like the blue one up above.....
Old May 11, 2003 | 09:40 AM
1986redbird's Avatar
more than likely you got some trash in the injector, but also check the fuel pressure. I would also change the fuel filter while your at it.
Old May 13, 2003 | 01:05 PM
sennap1's Avatar
Car: 91 TRANS AM
Engine: 350 V8
Transmission: 4L60
Axle/Gears: 3.43
thanks fot the heads-up on that! any other suggestions,on the possibilities? -brad
Old May 13, 2003 | 01:12 PM
gtabadboy's Avatar
I second the fuel pressure. Sounds like a possible lean condition. Also try some injector cleaner.
tyeo098
Nov 30, 2015 06:27 PM
racereese
Oct 3, 2015 03:46 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
Racerx974
Sep 19, 2015 10:16 AM
