Commander 950 harness question
Old May 12, 2003 | 02:25 AM
Odyssey's Avatar
I have a question about the 1985-92 TPI engine Commander 950 engine management kit that Summit sells from Holley. It's part number HLY-950-101.
Does this harness completly replace the stock harness ?? I plan on running a StealthRam and I need a 90-92 SD harness, but I dont want to buy a 300 dollar harness from Painless wiring then have to replace it with the Holley one when I order the Commander 950 kit. Did anybody order this harness or know what I need to know ? Thanx
Old May 13, 2003 | 01:19 AM
Odyssey's Avatar
Anybody... anybody...
Old May 13, 2003 | 10:59 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Try emailing Holley's tech support, you should get an answer within a day or so.
Old May 13, 2003 | 04:25 PM
Odyssey's Avatar
Good idea.. thanx!
Old May 13, 2003 | 08:05 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I've been seriously researching this myself as I may go this route too...yes the harness will replace the stock one because the Holley doesn't have hookups for emissions or TC lockup. Also the Holley harness is speed density so you don't need the Painless wiring harness.
You can also try asking on http://www.chevytalk.org/threads/pos...lapsed&sb=5&o=
Doug Flynn (the guy from Holley) is the moderator there and I've usually been able to find answers about the 950 by searching there. HTHs.
TheJoeY88
Dec 31, 2016 07:30 PM
fbirdroller
Sep 2, 2015 10:27 PM
355tpipickup
Aug 19, 2015 10:02 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
