Fix Droopy 87-92 Firebird Headlights
Old Jul 30, 2000 | 05:45 PM
kamac's Avatar
Car: 1989 Firebird
Engine: 2.8 MPFI
If you are one of the many people driving around with one or more headlights in the up position because you can't get the d@$% things to work, and refuse to shell out 300$ each to your local dealership for new ones, I may have a solution for you. If the motors still run when you push the button, but the lights don't move, or move intermittantly, the internal bushings are probably trashed. Rodney Dickman's Fiero Accessories sells a rebuild kit for 87-88 Fiero's that will work in 87-92 Firebirds. He also sells a kit for the earlier gen Fieros which may work in the earlier 3rd gen Firebirds, but I don't know for sure. 9$ (2 kits at 4$ + 1$ S&H) should solve your problems. The instructions are good, just remember that drivers and passenger sides are opposite in Firebirds and Fieros. It took me about 30-45 minutes to rebuild both headlights in my 89 Firebird. I also had to pull out the headlight switch and bend the "down" contact (third from left) in a little closer to make the lights go down. Now they work good as new, and I don't look stupid runing around in the daytime with the lights up. Rodney's website can be found at http://www.execpc.com/~rodney1/, or just type "Rodney Dickman" into a search engine. Hope this help save some of you some money and frustration.
Old Jul 30, 2000 | 08:23 PM
4mula350's Avatar
mine arent stuck up but they wont go up all the way by themselfs they'll go up about halfway u think that rebuild kit would fix that problem ??????mine is a 87
Old Jul 31, 2000 | 07:05 PM
Ritchy's Avatar
I bought the kit and fixed 87 FB. It works fine-just had a hangup for a while until they settled in.
Here are the links I used:
Firebird Headlight Fix Page: http://www.fl-fbody.com/members/bfra...tfix/index.htm
1987-1988 Headlight Actuator Rebuild Kits: http://www.execpc.com/~rodney1/87-88headlight.htm
86 FB stock 305 Qjet South California emissions
Old Oct 13, 2011 | 11:24 PM
Albani's Avatar
Car: 87 GTA
Transmission: Automatic
Axle/Gears: 2:73
Re: Fix Droopy 87-92 Firebird Headlights
I'm going to revive this thread because I need headlight motor help.
The links on the last post are no longer good.
Can anyone post up some links that may be simular?
Old Mar 13, 2012 | 11:45 PM
PHS's Avatar
PHS
Car: 1988 Firebird GTA conv
Does anyone have any new links, I bought the rebuild kit from Hawks third generation,but need some guidance.
1992CamaroGirl
Dec 25, 2017 08:45 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
firebirdchick28
Mid-West Region
Aug 16, 2015 02:52 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
