MSD6AL..what are your guys' experiences?
Old Jul 31, 2000 | 06:11 PM
Josh91Bird's Avatar
Car: 1991 Firebird
Engine: 412ci/sb
Transmission: Built 700R4
If not MSD which would you suggest? I will be running a 412sb with carb and stock HEI distributor. I want a better ignition than stock, and a rev limiter would be a nice safety feature. I have done a little research on these little boxes but I would like to know some "real-world" experiences.
91 Firebird 305/TBI - cam:.420/.442 204/214 - Hooker 1 5/8" headers - TFX PaceSetter Cat-Back - 3.42's Auburn Pro Posi - ASCD Ram-Air hood - Polished Formula Wheels w/Futura's - Open element - .5" Corian TB spacer - Lakewood LCA's - Hotchkis Lowering Springs - KYB Struts/Shocks - 14.78 @ 97.5 mph(G-Tech) - MacEwen MotorSports Whiteface Overlays
My Homepage
Old Jul 31, 2000 | 07:43 PM
Box of Rocks's Avatar
Bird,
I noticed a smoother idle, slightly better throttle response, and much improved cold start characteristics. I think they are a great upgrade from a points style ignition. I converted my points to magnetic (Pertronix), then added the spark box.
I'm very happy, but some guys have had problems with spark boxes on this site - and it has never really been determined why. I'd say that a good aftermarket or improved GM HEI would do the trick - as in a spark box is not needed, but there are many who say the $150 is a good investment no matter how good your current ignition is.
Gee, I'll bet this reply really helped clear things up for you - oh well.......
Good luck, whatever way you go.
BOR
Old Jul 31, 2000 | 08:08 PM
Guest
Guest
Posts: n/a
Yea, I heard the stories of bad boxes too, I wonder whats up with that?
I have a 6A that I was using on my TA for a while, its fine no problems with it.
I have a 6AL on my super-vibrating mustang, no problems with it either.
I didnt use the rubber mounting feet on either car. Maybe thats the trick?
Old Jul 31, 2000 | 08:17 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I was originally going to get a 6AL but wanted to get away from the old analog stuff and get a MSD Digital 6. After looking at the features I decided on a Holley's digital Strip Annihilator. A street car could just use the HP Annihilator. The nicest thing about the digital boxes are that they're smaller and have more features built into them.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
Old Jul 31, 2000 | 08:32 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I have had my 6AL on my ZZ4TPI for about two years with no problems. Not saying street cars really need the aftermarket ignition but ever look under the hood of just about every pro race car? You usually find some sort of MSD ignition box. I feel they are a quality piece.
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
theshackle
Sep 17, 2020 08:26 AM
gta90
Sep 15, 2015 04:00 PM
87iroctheo
Wheels and Tires
Sep 2, 2015 03:29 AM
neekolzun
Aug 24, 2015 04:59 PM
Street Lethal
Aug 14, 2015 08:25 PM
