my window fogs up when i run the AC
Old Jul 31, 2000 | 05:32 PM
88 Transam's Avatar
Alright i got a prob, every time i run the AC on my 88 Trans Am it puts out a lot of the air through the defroster vents and it fogs up my windows. Anyone who knows whats wrong and how to fix it please let me know.Thanks
[This message has been edited by 88 Transam (edited July 31, 2000).]
Old Jul 31, 2000 | 07:42 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Does the "fog" wipe right off cleanly? If not it sounds like a heater core.
Got a sweet smell??
Coolant on the floor?? (pass. side)
ASE Mechanic/Machinist/Smog Tech
RTKTGTR 1999 NBM T/A, flowmaster,FRA,Pro Kit,BMR STB, polished calipers.
1986 Chevy 3/4 ton pick up,flowmasters,4.10s,
1981 corvette FOR SALE
1995 ZX6R,Yosh,D207s
GO #3
Old Jul 31, 2000 | 07:49 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
does it 'fog' up on the outside or the inside? When I run my air, the interior gets so much colder than the exterior, on really humid nights my windshield will get so bad I'll need to use my wipers.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jul 31, 2000 | 11:00 PM
88 Transam's Avatar
The fog wipes off clean, and there isnt any sweet smell to the car.See my fist thought was the heater core but ive had it checked and its alright. Got any ideas on what might be wrong?
[QUOTE]Originally posted by Engineboy:
Got a sweet smell??
Old Aug 1, 2000 | 12:31 AM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
You may want to check to see if the drain in the heater box is plugged. If it is, water from the A/C evaporator could be sitting in there causing the problem. I have the problem, too, although the bad heater core isn't helping matters!
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Old Aug 1, 2000 | 12:41 AM
88 Transam's Avatar
Thanks for the advice, I havent hardly been able to drive anywhere without the window foging out on me, even when the weather is cool.I guess i better go check the evaporator see if its my problem.
[QUOTE]Originally posted by JP84Z430HP:You may want to check to see if the drain in the heater box is plugged. If it is, water from the A/C evaporator could be sitting in there causing the problem. I have the problem, too, although the bad heater core isn't helping matters!
jaridjohn
Jul 8, 2024 03:49 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
pfsteichen
Feb 9, 2016 06:59 PM
TheExaminer
Aug 26, 2015 04:59 PM
