is this normal
Old May 16, 2003 | 03:14 AM
SlowMaro's Avatar
is this normal
ok, after i put on my performer manifold, i kinda lost low end torque but gained ALOT of mid and upper rpm torque.....is that normal??? the lil adapter plate was 1 inch thick so, ..maybe the higher rise kills low end torque?? correct me if im wrong
Old May 16, 2003 | 11:01 AM
Vader's Avatar
Usually, it is the shorter,larger runners that reduce low-end torque. The larger runners lower the velocity of the intake charge at a given RPM, so cylinder charging at low RPM is reduced. You are compensated for that loss by gaining greater intake flow (and charging) at higher RPMs.
Old May 16, 2003 | 11:29 AM
SlowMaro's Avatar
so this is normal from a performer with the adapter plate acting like a space plate...??? regular performer, not rpm
Old May 16, 2003 | 05:57 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Thats normal. They are more tuned for top end performance than the factory manifold is.
Old May 16, 2003 | 06:36 PM
SlowMaro's Avatar
ok cool, thought maybe i bent a valve or had a leak or something...top end performance is great, ...low end is not so great, ...not horrible....just not GREAT ya know....
Fanatic1074
Oct 3, 2022 05:57 AM
Linson
Oct 1, 2015 09:50 PM
dusterbd
Sep 29, 2015 08:40 AM
BWilcox
Sep 20, 2015 12:19 PM
Stroopwafel
Sep 11, 2015 06:38 AM
