Which temperature sensor do I need to hook up a stock temp guage?
Old May 16, 2003 | 11:09 AM
Team P.S.I.'s Avatar
Car: 88 Z28
Engine: 408 Small Block
Transmission: TH350
Axle/Gears: 9" w/ 3.90's
Where is it located?
Where can I buy one?
Old May 16, 2003 | 11:15 AM
gtabadboy's Avatar
I believe it is located near the manifold on the drivers side of the block. If you do not have one there will be a bolt in the block where it should be. Get one at autozone. Also this gauge can be put anywhere that there is antifreeze (also in intake manifold). The best spot is near the manifold because you can not really see it.
Old May 16, 2003 | 11:23 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
  • It belongs in the driver's side head, between the #1 & #3 spark plugs. Put it there. That way the wire will reach.
  • The parts store.
Reddeath210
Oct 6, 2015 08:20 AM
355sbcTPI
Aug 19, 2015 04:38 PM
92camaroJoe
Aug 13, 2015 06:07 AM
stalkier
Aug 7, 2015 04:49 AM
