cam problem
Old May 19, 2003 | 03:12 PM
tpi iroc's Avatar
Car: 86 iroc
Engine: 355 400hp
Transmission: 700r4 race built
Axle/Gears: 4.10 posi
cam problem
i have an 86 iroc 305tpi.my friend has an 89 formula 305 tpi we just put a 95 lt1 cam in his car (or so the guy says) and got nothing. i have hooker headers, dual flows, .420 .442 cam and ads superchip and big mouth intake self ported runners and plennum. he has edelbrock headers dual flows, underdrive pulleys, hypertech chip and 95 lt1 cam, should be .447, .459 something like that. both have 2.73 gears. i walk away from him like nothing the same as before the cam, should he not be faster? are we doing something wrong with his car his timing is at 10 degrees as is mine fuel press 40. any suggestions will be aprreciated.
Old May 20, 2003 | 05:04 PM
tpi iroc's Avatar
Car: 86 iroc
Engine: 355 400hp
does it need roller rockers?
Old May 20, 2003 | 09:32 PM
Vader's Avatar
TeePee Eye,
You have a ported plenum and runners, while the '89 apparently doesn't. Advantage - '86.
You don't really know the lift and duration of the cam in the '89 unless you measured it. Yours might be better. Advantage - possibly '86.
You have the ADS PROM, the '89 has a HyperScrap PROM, which probably does nothing significant on a MAF car. Advantage - '86.
Your car most likely has a 2.77 Borg Warner axle, while the '89 probably has a 2.73 Saginaw axle. Advantage - '86.
The underdrive sheave on the '89 is really doing nothing except making the alternator work harder and possibly limiting coolant flow at lower engine RPM. There's little or no power advantage on a street application, so that one is a wash.
Old May 20, 2003 | 09:40 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Yeah, what he said...
Ya know Vader, that reply kinds sounds like a Motor Trend comparison!!!
Old May 21, 2003 | 09:14 AM
tpi iroc's Avatar
Car: 86 iroc
Engine: 355 400hp
alright thanks ill see about geting him to change the chip and do some porting, and see what we get. you are right about the gears
Street Lethal
Apr 30, 2019 12:14 PM
nuggie
Aug 25, 2015 01:27 PM
neekolzun
Aug 24, 2015 04:59 PM
theurge
Aug 21, 2015 12:46 PM
Fronzizzle
Aug 9, 2015 01:15 PM
