Car is handleing INsanely!
Old May 19, 2003 | 09:19 PM
05kcilS's Avatar
Car: 1991 Z28
Engine: 350 L98
recently had front suspension replaced.
included:
inner/outter tie rods
tie rod sleeve
center link
idler arm
wheel bearings
lower ball joints
... here is the problem. I'm driving... and when i hit a bump... the car seems like i have limited control of the steering. Could a bad alignment cause this? I'm getting an alignment tomorrow. but honestly it is just scary at highway speeds. It seems to happen mostly when i hit a bump/dip in a road
Anyone ever have this problem? geez, i hope the alignment will solve this.
Old May 19, 2003 | 09:22 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
i would get an alignment. Its a MUST to get an alignment whenever you change/remove/replace front suspention and steerign components.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
NBrehm
Aug 25, 2015 11:49 PM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
