Crankcase pressure/ oil leak
Old May 20, 2003 | 06:35 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Hi..
After my procharger install its leaking oil all the time( at idle and so on...)
Its leaking oil when its hot at the oilpan/camchain cover. I have removed my PCV and just put a hose and vents in to atm. but it still leaks.
Can I use my AIR pump as a vacuum pump and draw oil fumes from the crankcase to releave some pressure.
any ideas?
/N.
Old May 20, 2003 | 02:30 PM
snakeskinner's Avatar
using a vacuum pump to relieve pressure is the key. If yours will work is another question. If you have too much pump, you're just gonna suck oil out of the crankcase and dump it out. Not to mention the pump might not like the oil. I've heard of using electric pumps off something like a Ford Tempo but I am not positive. This has become popular on some bracket race cars so you might check it out on some of those message boards.
Old May 21, 2003 | 04:44 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
LT1 have electric air pump. If I find one I will try it on, should I plug the RH valve cover to create more vacuum?
/N.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
