Serpentine belt tightness
Old Aug 1, 2000 | 08:43 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I Took off my smog pump and got too new belts 94.5 and 95.2 (only belts that were close) and the 94.5 Maxed out the tentioner and the 95.2 is just before the first mark on the scale
.|<- Where it is
\_|___| | | |_/ <- Markings on scale
89 FORMULA 350 Edelbrock Cat-Back March Pulleys
Accel Cap ,Super Coil SLP Airfoil K&N Filter 180 stat , Fan Switch
Taylor 8mm Spiral Pro,TB Bypass ,Energy Sus bushings ,Hotchkis STB ,MSD 6AL ,Edelbrock TES's ,Hi Flo Cat ,Crane AFPR ,1/4 time 14.4@98
[This message has been edited by Mkos1980 (edited August 01, 2000).]
Old Aug 1, 2000 | 08:46 PM
Blade's Avatar
And your question is...
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires...
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Old Aug 1, 2000 | 09:33 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
is it safe
Old Aug 1, 2000 | 09:35 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
"The belt is stretched and needs to be replaced when the indicator marks reaches the limit of clockwise travel."
So a new belt should start with the indicator mark on the tensioner moved as far counter clockwise as possible to the indicator on the passenger side of the car. When the belt is worn out the indicator mark will rotate clockwise and point to the driver side mark.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
