Valve Spring Tools...
Old May 21, 2003 | 01:46 AM
smithtc's Avatar
I'm looking at these parts from Jegs
778-66774 300 lb spring pressure tester $229.99
778-66775 700 lb spring pressure tester $229.99
778-66832 Valve Spring Compressor $99.99
Heads off of motor. Is there a better bang for the buck on the pressure tester? For the valve spring compressor I am wanting one that is easy to use, preferably one that will hold on the big end of the valve...I think...unless there is a better way to do it.
Jegs was the only supplier I have seen so far that has these.
Old May 21, 2003 | 01:58 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
it really depends on what you plan to do. If you are going to be using them frequently, then I would say get them. If this is like a one time use project, you are probably better off getting your springs checked at a local machine shop.
Just my 2 cents.
Old May 21, 2003 | 02:06 AM
smithtc's Avatar
No, not a one time thing...obviously, or so I thought. Why the hell would I spend hundreds of dollars to use something one time?
Not asking if I should get them, but wether there is a better tool for same cost, or equal tool for less cost?
What is difference b/w the 300lb tester and the 700lb tester? guage? Is the guage easily interchangeable?
Old May 21, 2003 | 05:28 AM
ede's Avatar
ede
besides the gauge there may be differance in seals, but i doubt it. not sure what k line has but i'd look there 800-241-0936
Old May 21, 2003 | 05:51 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Are you planning on going into business testing springs?
Or, to look at it another way: Why spend $230 to test a set of $60 springs, that probably ought to just be replaced anyway? There's more to a spring's condition than just its measured tension; that won't necessarily tell you the likelihood of one breaking.
I guess it boils down to a question of whether using a tester is the best way of dealing with valve springs in the first place, in your particular situation. What it's really good for is for teardown in between races, when you are running springs that cost $300 a set like some of the high-end ones do. For a street-driven motor, it's usually better to just buy new ones if you have any doubts, rather than fooling around with testing them.
But as far as the tools themselves go, Comp makes one that goes in a drill press or a bech press, for a little over $100. Look at their catalog for the part #, and try Summit. Manley also makes a real cool one that hooks to your torque wrench and checks seat pressure with the spring installed.
The spring compressor, on the other hand, is an extremely useful tool. That one is a bit pricey. Lisle makes one that you can get at parts stores and such. Sears has one for about $25 or so IIRC. Snap-On, Mac, etc. also have them. You might want to look at ones that you use while the heads are on the car; Manley makes one of those too, that works on installed heads.
Old May 21, 2003 | 09:21 AM
machine tools generally aren't cheap. Is that valve spring compressor a manual one, or is it power?
Old May 21, 2003 | 11:41 AM
smithtc's Avatar
This is the compressor I was looking at:
http://www.jegs.com/cgi-bin/ncommerc...23&prmenbr=361
I already have one of the cheap ones ($20) that you just lift up on it and pry down the spring and pop it loose from the keepers/retainer.
I'll look up Manley's website and see what all they provide.
pjsparts
Oct 29, 2025 06:39 PM
crzycamaro86
Sep 12, 2015 05:51 PM
ericjon262
Sep 11, 2015 06:07 PM
lakeffect2
Sep 7, 2015 03:52 PM
