What did I just break?
Old May 21, 2003 | 04:43 PM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
This is on my '88 Camaro in the sig...
I was pulling plug wires off of the distributor when my "flying hand" pulled off and broke a part (at least I didn't break my knuckles like I usually do ). Basically, it's a small black cylinder with a diameter similar to that of a dime. It has three small vacuum hoses comming out of it: one directly into the intake plenum, the another to the black cannister close to the driver's side headlights (just forgot the name), and the last one disappears off into the wiring harness going through the firewall.
Any idea what this part is called and where I can get a new one from?
Old May 21, 2003 | 06:58 PM
rezinn's Avatar
Sounds like the EGR solenoid. Mine doesn't exactly look like that on my 87, but maybe they changed to a different design.
Old May 21, 2003 | 11:27 PM
pigsticker's Avatar
Car: 1992 z28
Engine: Vortec 350 TPI
Sounds like a vacuum check valve. I've seen them at Advance auto. They probably cost around 4 or 5 dollars.
Old May 21, 2003 | 11:59 PM
sancho's Avatar
I found one at AutoZone--it's a vacuum check valve. Thanks for the replies!
UltRoadWarrior9
Apr 28, 2020 10:39 PM
apie2546
Oct 16, 2016 02:24 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
sjorgens
Oct 1, 2015 07:54 PM
mfp189
Sep 27, 2015 09:25 AM
