install headers before or after swap
Old Aug 2, 2000 | 12:25 AM
rsilver's Avatar
I am going to swap out my 305 in my 91 rs for a 350 probably this winter.(both are TBI engines) Should I go ahead and install headers, 3inch Y-pipe, and 3 inch cat back now or will it be a lot easier if I just wait till I put the new engine in?
I was thinking about getting the exhaust work done now and making sure brackets, Etc and everything fit and other bugs are worked out ahead of time but not sure if it will make the 350 swap easier or if its worth it now.
Would 1 5/8inch headers be ok for both engines
assuming I will probably only be around
275 to 300 Hp with the new 350??
Once again, thanks...
91 camaro RS convert
t-5
open element air cleaner
TBI spacer
Flowmaster muffler
Old Aug 2, 2000 | 01:11 AM
Mike '91 Z28's Avatar
If you happy with the car now and can wait til you get the 350 this winter, I would wait to install your headers. It's is a PITA to install them. Especially twice . I did not run in to any problems with installing them, it is pretty straight forward.
Old Aug 2, 2000 | 01:20 AM
Philip92-z28's Avatar
Like what Mike said , they are a PITA to put in , but if you do it now you will have everything fitted up when you put in the 350 . One less thing to do then .
1984HO
Mar 19, 2021 11:59 AM
Wesly_66
Aug 26, 2015 09:55 PM
InfinityShade
Aug 22, 2015 08:00 PM
sreZ28
Aug 14, 2015 07:48 PM
drathaar907
Aug 6, 2015 04:20 PM
