Can I buy an AC-delete serpentine belt?
Old May 22, 2003 | 07:37 AM
blue86iroc's Avatar
Car: 1986 IROC-Z
I picked up a set of serpentine belt brackets for my '86 Camaro the other day. I got everything that I need except for an alternator and the AC-delete pulley (I don't have air conditioning anymore). Is there a special length non-AC serpentine belt that I can use until I buy the pulley from GM?
Old May 22, 2003 | 07:58 AM
Vader's Avatar
Blue86,
You can purchase poly-V belts in almost any length in 10mm increments. Just stop shopping at auto parts stores and look at industrial power transmission suppliers. All you'll need to know is the number of ribs, section width, and length you want.
Old May 22, 2003 | 09:09 AM
blue86iroc's Avatar
Car: 1986 IROC-Z
Originally posted by Vader
Blue86,
Hmm, good idea. Now, with that said, do you know approximately the length that I'd need? I'd imagine that it doesn't have to be super-accurate because the tensioner will supply the proper amount of pressure to the belt.
Old May 22, 2003 | 12:02 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
When I had to bypass the A/C on my 96 Camaro, I just measured the approx size with the stock belt and went to the parts store and bought 3 belts, each one longer in 1" increments, found the size I needed and returned the other 2.
Old May 22, 2003 | 01:01 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
Sounds like a good idea. I think that's what I'm going to do once I get my alternator.
Galaxie500XL
Feb 1, 2020 04:53 AM
codeysabatini
Nov 10, 2015 04:07 PM
iroczguy86
Sep 13, 2015 02:22 PM
MORREALE5
Sep 10, 2015 08:58 AM
buckshot63
Interior Parts Wanted
Sep 3, 2015 08:10 AM
