What sensors are used by the ECM in open loop?
Old May 22, 2003 | 11:40 AM
Chet's Avatar
Car: GTA
I'm trying to track down a cold (as in the engine has been sitting for >8 hours, not outside temps) stumbling problem at low rpms, and I've determined that it only happens in open loop. After the car warms up for about 5mins and the idle lowers it runs fine, the problem is gone. I'm getting no trouble codes and the car has fresh plugs, wires, cap, and coil. Does anyone know what sensors to check?
Old May 22, 2003 | 11:45 AM
scuzzy's Avatar
it's normal. your car probably doesn't like to run too rich
the ECU reads every sensor except the O2 sensor in open
loop, the O2 sensor must be at ~600F to function properly.
Additionally, during open loop, the timing tables and other
such values have been hard coded, and it runs off of them
to keep the car going. open loop runs much more rich.
If you're not getting codes, I would say your car is
running fine and all the sensors are working, it just doesn't
like to idle very rich. (which is what open loop is, a rich idle)
Old May 23, 2003 | 02:36 PM
Chet's Avatar
Car: GTA
Well, that would be fine if it was running rich but I think its running lean. When it is stumbling real bad I can sometimes hear it popping thru the intake.
Old May 23, 2003 | 02:42 PM
82-T/A [Work]'s Avatar
I think there's a sensor on the intake that controls the cold-start injector. It's a type of temperature sensor.
Maybe that's bad?
I would also try doing a real heavy duty carbon cleaning.
You have to get the stuff that the dealerships use.
The only place I know where to get it is from some dude that owns the Fiero Factory in Alabama.
He sells you a kit with 3 cans. Two go into the fuel, and one is sprayed into the intake. It's heavy duty detergenty type stuff. You put it in on a quarter tank. It COMPLETELY cleans your pistons, and cyl chambers and intake valves... everything.
www.thefierofactory.com
or fierofactory@juno.com
Eric2ndGen
Nov 5, 2015 01:51 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Jae992
Aug 27, 2015 09:07 AM
CORV3TT3
Aug 23, 2015 11:26 AM
beast94
Aug 20, 2015 06:44 AM
