Leaking Gas!!!!! HELP!!!
Old May 22, 2003 | 03:07 PM
Syxx613's Avatar
Car: 1987 Trans Am GTA
Transmission: 700 R-4
Hi, i just got home from school and as me and my friend were pulling in my driveway i saw that i had a huge puddle underneath my car, so i got out and checked it and it was gas!! i see that it is coming from underneath the engine gears. I just got this engine put in, its a 350. And 2 days ago i put a new carburetor on it and it started up. However i dont really know jack about carbs and i think i put it on wrong or something. However, whats going on? what can i do?!
Old May 22, 2003 | 03:26 PM
rezinn's Avatar
Underneath the engine gears? Where is that? If you've got a gas leak, just find where it's coming from. Check all of the fuel lines and the connections they go to, the fuel filter, fuel pump, etc.
Old May 22, 2003 | 03:40 PM
Syxx613's Avatar
hmmm.... well my only problem is, i can only see it dripping from the bottom of the engine and thats it. Nothing on top of the engine is leaking, and i cant really get underneath it too well. I just looked at it again and ive collected a LOT of gas already, its a pretty steady drip. i just installed a new carb 2 days ago, could that have anything to do with it?
Old May 22, 2003 | 07:53 PM
Dan88IrocZ's Avatar
Well a carb operates with gas. So I'd guess you did something wrong, or didn't tighten something right, punctured a gas line..something.
Old May 22, 2003 | 07:59 PM
Syxx613's Avatar
ok thanks for the advice, ill check those things.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
dbrochard
Oct 3, 2015 12:43 PM
TBRays98
Sep 6, 2015 05:05 PM
tgp1990
Sep 4, 2015 06:24 AM
