need help with starting problems on 90 IROCZ.
Old May 22, 2003 | 08:48 PM
FbodyFan's Avatar
hi my brother has a 90 irocz 350TPI.and its having problems starting when its hot or cold.the engine doesnt crank doesnt even try to start what would cause this problem VATS?kind of annoying not having ur car start.my 96z28 doesnt have this problem.but i heard the Coolant temp sensor can cause it not to start is that true?i use to have a 87GTA TPI i havent had that problem so i am thinking its vats.also its not the ignition module,replaced that.but if anyone knows the problem would great thanks.also how can i bypass the VATS?
Old May 22, 2003 | 09:37 PM
Dragons91RS's Avatar
Car: 91 Camaro RS
Engine: 305 LO3
Transmission: 700-R4
I would check the coolant temp sensor and the plug for it.
I had a problem recently where my car would run like crap want to stall out and not start. it would crank but was hell getting it to start, and it did come out to be the coolant temp sensor. well actually the plug for it. the wires going into the plug for the temp sensor had a short in them. my mech replaced the plug and I havent had a problem since.
this may sound stupid, but make sure the hatch it closed all the way(even if it looks closed push down on it). I had a problem recently where the car had power but the engine wouldnt crank at all, I was really worried thinking my starter may have gone bad with no warning. I turn around get some thing out of my hatch shut it, tryed starting the car one more time b4 going in and it fired right up.
Old May 22, 2003 | 11:32 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Starter.
Old May 23, 2003 | 08:47 AM
Vader's Avatar
Watch the SECURITY lamp on the dash when the starter is engaged. What does it do?
Old May 23, 2003 | 08:56 AM
FbodyFan's Avatar
last night the car wouldnt start,this morning it start right up.The light blinks a couple times when it starts then goes away.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
