push rod swap from 882 heads to 083's ??
Old May 23, 2003 | 08:28 AM
fakeyankee's Avatar
Car: 87 T/A
Engine: LM1 350
Transmission: 700 R4
This is probly a no brainer for some of you guys but..... can i use the same push rods while swapping the above heads ?? A friend is giving me 1.5 roller tip rockers to replace the stock rocker arms. Does anyone forsee a problem with this matchup ??? Would like to use the stock push rods to help keep cost down.
Old May 23, 2003 | 09:20 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Push rods
Just make sure your 083's have a slot for the push rods and not a hole. With a hole you will need self-aligning rockers.
customblackbird
Aug 15, 2021 10:16 PM
Reborn756
Sep 4, 2015 03:42 AM
lakeffect2
Aug 23, 2015 08:44 AM
86White_T/A305
Aug 17, 2015 12:16 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
